Forums >> Revit Building >> Technical Support >> dimension center lines in drafting view
Wed, Dec 10, 2008 at 10:17:02 AM | dimension center lines in drafting view
aharris509
I am drawing a detail in a drafting view. is there a way to make my dimensions read my detail lines as center lines?
Mon, Mar 9, 2009 at 8:55:21 PM | dimension center lines in drafting view
jakubc7
has anyone got a solution to this. i really would like to be able to "force" a center line dimension
Tue, Mar 10, 2009 at 7:18:39 AM | dimension center lines in drafting view
Why do you need to force this?
In the properties of any arc, you can make the center mark visible.  And if your center is out of view, you can drag the radius dim value and enpoint back into range.
Tue, Mar 10, 2009 at 1:30:58 PM | dimension center lines in drafting view
LIZARD2806
3.5 Stars: 7 Votes
There is only one way I know to do this, but it involves adding a family.  You can create a detail component family which will have a center reference plane.  If you use that instead of a <centerline>, the program will recognize it as a centerline.  I made the family and it is attached.  Let me know if this works for you.
Sun, Mar 15, 2009 at 8:41:21 PM | dimension center lines in drafting view
jakubc7
Thanks lizard ... sounds like that should work. yet another round way to do  what should be a simple thing ...
jakub c
Fri, Apr 6, 2018 at 3:42:29 PM | dimension center lines in drafting view
carlos72
Lizard
This is good.
orthogonal dimensions to radial dimension center point
Fri, May 14, 2010 at 3:22:32 PM
Dimensioning Drafting????
Thu, Feb 6, 2014 at 2:42:45 PM
Dimension center line of foundation
Thu, Oct 4, 2007 at 7:40:43 AM
dimensioning to a center mark of an arc
Wed, Jul 5, 2023 at 3:13:09 PM
Dimensioning tolerances to use align dimension with grid lines ?
Tue, Feb 9, 2016 at 11:18:30 AM
Page generation time: 2.1288
