Forums >> Revit Structure >> Technical Support >> Line pattern scaling for joists
Tue, Dec 9, 2008 at 8:12:59 PM | Line pattern scaling for joists
dmcillini
Within 'settings - object styles' I have globally set the line pattern for web joists to be a line pattern that I have defined called 'joist lines' that is obviously a series of dashed, dots, and spaces.  In some locations, this pattern looks correct, while in others it does not.  The pattern seems to change based on the length of the joist, like it is somehow trying to scale the dots, dashes, and spaces.  It also looks different based on the length of the joist.  Even weirder, the line pattern will look different based on the type of the joist - i.e. the pattern for a 32LH08 will sometimes look different than that of a 20K6.  Does anyone have any idea what is going on here??  Thanks!
Tue, Apr 21, 2009 at 10:55:50 AM | Line pattern scaling for joists
mikemaddog
I'm having this same problem with some joists showing up as dashed dot dot dashed while others are showing up just dashed. when i switch from 1/4" dashes to 3/8" dashes the joists that were showing up right are now showing up wrong and vice-versa. any help would be great.
thanks
SETTING THE LINE PATTERN FOR A JOIST IN PLAN
Tue, Jan 12, 2010 at 3:44:51 PM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Pattern scaling relative to views
Thu, Nov 13, 2008 at 10:40:19 AM
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:15 AM
Line weights of girders vs joists
Fri, Feb 24, 2006 at 12:56:21 PM
Page generation time: 0.8283
