Forums >> Revit Building >> Technical Support >> Rotating details on sheets without rotating their callouts in plan
Tue, Dec 9, 2008 at 4:55:51 PM | Rotating details on sheets without rotating their callouts in plan
alibi0614
Part of my building is rotated about 15 degrees from the rest of it.  I'd like the enlarged plans to read at the same angle as the building on the sheet, but to keep my floor plans clean, i'd like the callouts to be lined up with the floor plans too.  when i align the callouts with the plans, the enlarged plans show up true north, and when i rotate the crop region in the enlarged planto display it correctly, the callout also rotates on the sheet.  any way to get around this?
thanks!
Tue, Dec 9, 2008 at 4:56:16 PM | Rotating details on sheets without rotating their callouts in plan
alibi0614
version 2009.  sorry!
Tue, Dec 9, 2008 at 5:08:50 PM | Rotating details on sheets without rotating their callouts in plan
tim123
4 Stars: 19 Votes
You can overide the callout properties so that the lines are white and manually draw the callout.
Wed, Dec 10, 2008 at 5:28:37 PM | Rotating details on sheets without rotating their callouts in plan
alibi0614
There's no other way?  i have a lot of callouts and it seems like a lot of extra lines to keep track of and a lot of work to set up.
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating a Project
Thu, Jun 29, 2006 at 9:08:00 AM
Page generation time: 1.5381
