Forums >> Revit Building >> Technical Support >> In place counter tops.
Tue, Dec 9, 2008 at 4:14:36 PM | In place counter tops.
aaronkennedy
I am making some inplace counter tops but I cannot figure out how to make them the same "material" as families in the library.  I cannot see the base cabinets and the counters are a different color than the ones from the library.
Any advice?
Thank you,
AAron
Tue, Dec 9, 2008 at 4:18:06 PM | In place counter tops.
tim123
4 Stars: 19 Votes
Go back into edit mode and apply the material there.
Tue, Dec 9, 2008 at 4:18:54 PM | In place counter tops.
Edit the cabinet family & find out what they are there.
Tue, Dec 9, 2008 at 5:31:19 PM | In place counter tops.
aaronkennedy
I have deconstructed the counter top and tried to make mine just like it. I still cannot see through the masking region.  How do they make it so you can see cabinets under the masking region anyway?
Tue, Dec 9, 2008 at 10:34:38 PM | In place counter tops.
critter
Add a "material and finish" parameter in the edit mode. Why are you making an in place counter top anyway? I would just make a family. Just my two cents.
Getting away from have Bench Tops/Counter Tops with Parametric holes for Sinks
Wed, Aug 8, 2012 at 6:51:22 PM
Can anyone explain the phantom lines in this family?
Tue, Oct 7, 2008 at 11:25:39 AM
Cabinet / Counter visibility
Wed, Nov 16, 2011 at 2:24:41 PM
CounterTop
Tue, May 25, 2010 at 6:23:20 AM
counter top model
Mon, Feb 28, 2011 at 2:11:16 PM
Page generation time: 1.6082
