Forums >> Community >> The Studio >> Default 3D View Broken?
Tue, Dec 9, 2008 at 3:25:45 PM | Default 3D View Broken?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
My default 3D View is missing most of my model... but the model is all there in the rest of the views and new 3D views.  Is there anyway to recreate this defaulted 3D view?  Or what should I do?  Is this happening because the file size is getting too big?
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Tue, Dec 9, 2008 at 3:30:55 PM | Default 3D View Broken?
4 Stars: 205 Votes
Hi Dlicata, did you delete that 3D View and create a new one to check???
Edited on: Tue, Dec 9, 2008 at 3:31:11 PM
Tue, Dec 9, 2008 at 3:53:16 PM | Default 3D View Broken?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I didn't delete it but I created a new 3D view and the model showed up just fine.  How can I make this new 3D view my default 3D view?
 LHAA
Reno, NV USA
Tue, Dec 9, 2008 at 3:56:38 PM | Default 3D View Broken?
The whole model is in your 3d view... you just have it cropped.  While in the 3d view, click on the crop (do not crop) button at the bottom of the view...4th from right.
Edited on: Tue, Dec 9, 2008 at 3:57:33 PM
Tue, Dec 9, 2008 at 4:08:50 PM | Default 3D View Broken?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I clicked it and it didn't change anything.
 LHAA
Reno, NV USA
Tue, Dec 9, 2008 at 4:17:38 PM | Default 3D View Broken?
It appears that you have a section box.  Click on the box & you will see push/pull arrows or just gotot VP and uncheck section box.
Tue, Dec 9, 2008 at 4:29:39 PM | Default 3D View Broken?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
No I checked and the section box isn't checked... I think the view is really broken because when I fly around the building it causes an "irrecoverable error and terminates the program"...
 LHAA
Reno, NV USA
Tue, Dec 9, 2008 at 4:34:10 PM | Default 3D View Broken?
You have a memory issue on your system.  As you work in REVIT, memory is used with each view opened.  When you close the view, some of the memory is returned but not all.  The fix is to close REVIT at least once a day ...
Tue, Dec 9, 2008 at 4:40:06 PM | Default 3D View Broken?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
That's weird because I open and close Revit all day and I still haven't seen a change...
 LHAA
Reno, NV USA
Tue, Dec 9, 2008 at 4:43:48 PM | Default 3D View Broken?
I've run out of possibilities ... You may have a corrupt file.  Have you audited it?  If that doesn't fix your problem, you may have to talk to AutoDESK.
Tue, Dec 9, 2008 at 4:53:53 PM | Default 3D View Broken?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
The file is fine in every other view but this 3D view... so I guess I'll audit it and go from there.  Thanks for the help guys! Smile
Edited on: Tue, Dec 9, 2008 at 4:54:13 PM
 LHAA
Reno, NV USA
Wishlist - Default perspective 3d view
Fri, May 2, 2014 at 9:31:09 AM
RevitCity Website is Broken.
Mon, Dec 2, 2024 at 11:16:24 AM
Where's my default 3D view?
Wed, May 6, 2009 at 9:44:52 AM
Set default 3D view
Tue, Feb 18, 2014 at 11:31:43 AM
2014 - Revisions on Sheet dialog box is broken [ 1 2 ]
Mon, May 19, 2014 at 3:59:36 AM
16
Page generation time: 0.6299
