Forums >> Revit Building >> Technical Support >> Problem with 3D view
Mon, May 23, 2005 at 3:03:41 PM | Problem with 3D view
Aaron
I have a problem...I have a building with multiple levels....I have walls drawn on the basement level and level 1. All the walls are visible in the elevation views but when I go to 3D view only the basement walls are visible...I've checked everything I can think of. Nothing is frozen I checked the properties and visibilities and everything. Am I missing something? Thanks for the help. Im using revit 8 Post edited on 2005-05-23 15:03:48 Post edited on 2005-05-23 15:04:16 Post edited on 2005-05-23 15:04:35
Mon, May 23, 2005 at 3:57:56 PM | RE: Problem with 3D view
TomDorner
4.5 Stars: 25 Votes
Are you using phases? If so check phase filters. Are you using worksets? Are they all on? Do you have a section box turned on?
Mon, May 23, 2005 at 4:10:04 PM | RE: Problem with 3D view
Aaron
thanks...it was the phasing...this is the first project we are using revit for...I know all the modelling tools but don't know all of the scheduling and things like that...I guess it's time for a tutorial ha. Thanks again.
View range problem
Wed, Nov 5, 2014 at 10:18:37 AM
Problem with door changing in 3D view
Mon, Jun 25, 2007 at 11:29:09 AM
Text problem on 3D views
Tue, Nov 9, 2010 at 8:20:38 AM
Split View & Dimension Problem
Tue, Jun 18, 2013 at 10:06:03 AM
Problem with duplicating view as a dependant
Wed, Jun 3, 2009 at 6:53:15 AM
Page generation time: 1.3820
