Forums >> Revit Building >> Technical Support >> Problem with Copy/monitor of Room tags
Mon, Dec 8, 2008 at 4:03:30 PM | Problem with Copy/monitor of Room tags
jkurtz12
Hi,
I have done extensive searching and have not found an answer to this question.  I cannot Copy/Monitor the room tags from the linked file.  I want to be able to move the room names/numbers in the MEP plans that I have setup.
Thanks in advance.
Copy Architect's Room Tags?
Thu, Jan 31, 2008 at 1:08:41 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Page generation time: 0.5916
