Forums >> Revit Building >> Technical Support >> Deleting Doors
Mon, Dec 8, 2008 at 7:13:22 AM | Deleting Doors
Suzanne84
Revit Architecture 2009.
Hi, Is there a way you can get revit to keep doors in the schedule that you have deleted from the model. With rooms when you delete them in the model they come up with "Not Placed" in the schedule until you delete them from there. I want to do the same with doors so I know which ones have been deleted.Thanks
Mon, Dec 8, 2008 at 9:12:16 AM | Deleting Doors
Dafpfy
3.5 Stars: 11 Votes
you would probebly be able to do this with phasing.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Dec 8, 2008 at 9:22:47 AM | Deleting Doors
afc4
3 Stars: 3 Votes
No you cant do this. When you delete the door out of the model it removes it form the schedule becase it no longer sees it in the project. You could do it with phasing but that would just show you a different schedule that looks at demolished doors.
doors in curtain walls
Wed, May 23, 2007 at 2:04:06 PM
deleting levels without deleting associated objects on it.
Thu, Aug 1, 2013 at 6:20:35 AM
Anyone have pocket doors or pivot doors?
Tue, Jun 25, 2019 at 12:37:56 PM
dOORS AND DOOR SCHEDULES
Mon, Aug 6, 2007 at 11:28:15 AM
Infilling element replaced by a later phase insert must be the same type as the
Fri, Jan 6, 2012 at 8:46:24 AM
Page generation time: 1.6733
