Forums >> Revit Building >> Technical Support >> Help... Applying Rendering Texture to Sloping Wall
Sun, Dec 7, 2008 at 9:28:43 PM | Help... Applying Rendering Texture to Sloping Wall
bballarchitect
I have an outwardly sloping exterior wall made from a mass, and when I render it the corrugated metal texture map it is applied in a circular pattern. Is there a way to make the material show correctly? I am using revit 2008.
Mon, Dec 8, 2008 at 5:47:54 AM | Help... Applying Rendering Texture to Sloping Wall
4 Stars: 205 Votes
Well, images of the problem helps.....
Uneven texture on wall rendering
Fri, Sep 28, 2012 at 5:27:55 PM
SLOPING CAST STONE WINDOW SILL APPLICATION
Thu, Feb 28, 2013 at 8:38:42 AM
Texture Maps & Rendering
Fri, Nov 4, 2011 at 3:54:17 PM
curbed wall texture alignment
Sat, Dec 1, 2012 at 5:47:58 AM
Sloping wall
Mon, Sep 24, 2007 at 9:10:38 AM
Page generation time: 1.0007
