Forums >> Revit Building >> Technical Support >> curved exterior stairs
Sat, Dec 6, 2008 at 4:37:06 PM | curved exterior stairs
RainaMc
RainaMc Avatar
Hello,
I am working in 2008.  See attached picture front stairs this is a common thing my company does but I have no clue how to do this in Revit.  Does any one have any suggestions.
Thanks,
Raina
Sun, Dec 7, 2008 at 4:24:26 AM | curved exterior stairs
tim123
4 Stars: 19 Votes
This is suprisingly easy to achieve.  Edit your stair and delete the straight boundaries (green lines) and draw new ones using the boundary line in the sketch tools.  Delete straight risers and redraw the curved ones using the riser line tool.  Make sure all the lines meet up.  Finish the sketch and - curved stair complete.
Mon, Dec 8, 2008 at 6:25:41 PM | curved exterior stairs
RainaMc
RainaMc Avatar
Thanks tim123.  Got the stairs curved no problems.
See attached again not sure what to call this part as its not really a handrail nor is it stairs.  I thought maybe to make it like a slab but then it is not sloping with the stairs.  Or would the slope arrow tool work?
Tue, Dec 9, 2008 at 8:35:07 AM | curved exterior stairs
tim123
4 Stars: 19 Votes
Do you mean the side walls shown in the previous image?  I would do these as walls and delete the handrail.
Tue, Dec 9, 2008 at 9:23:53 AM | curved exterior stairs
RainaMc
RainaMc Avatar
Oops I meant to attach this picture and also the stairs.  I guess you could call it a side wall.  How would you get the wall to curve up at the very end to connect to the porch?  This is in 2008.
Thanks,
Raina Mc
Tue, Dec 9, 2008 at 10:39:41 AM | curved exterior stairs
tim123
4 Stars: 19 Votes
Draw your curved wall and use a void yo cut it - see attached.
Tue, Dec 9, 2008 at 11:30:22 AM | curved exterior stairs
RainaMc
RainaMc Avatar
How do you do a void cut in a wall?  I don't see that option.  I am still new at this.
Tue, Dec 9, 2008 at 12:06:06 PM | curved exterior stairs
4 Stars: 205 Votes
Go to "Moddeling-Create" use "Wall" category then "Void" - extrusion....
Tue, Dec 9, 2008 at 2:10:07 PM | curved exterior stairs
RainaMc
RainaMc Avatar
Ok here is what i have.  Thanks TyphoonI followed the steps "Moddeling-Create" use "Wall" category then "Void" - extrusion.... which I am sure works but I am doing something wrong.  How can I get it to slope, like the picture Tim123 posted?  Are there any tutorials or other information out there that might help me to understand this function of Revit?  Or can someone give me a step by step?
Thanks again,
RainaMc
Tue, Dec 9, 2008 at 2:25:00 PM | curved exterior stairs
RainaMc
RainaMc Avatar
see attached 2008 file.
Tue, Dec 9, 2008 at 2:31:59 PM | curved exterior stairs
4 Stars: 205 Votes
Hi, see the video: http://screencast.com/t/BnjcO83Sug
Tue, Dec 16, 2008 at 1:13:51 PM | curved exterior stairs
RainaMc
RainaMc Avatar
Typhoon,
See attached it works.  Thank you so much for the video very much appreciated.  Only one more thing is there a way to show the brick on top where the void extrusion is?
Thanks again for all the help,
RainaMc
Tue, Dec 16, 2008 at 2:16:02 PM | curved exterior stairs
#13
4 Stars: 205 Votes
Use the "Paint Tool"... see the image attached
Tue, Dec 16, 2008 at 2:42:51 PM | curved exterior stairs
#14
RainaMc
RainaMc Avatar
Thanks!
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
Curved Stairs in a Pie Shaped configuration
Tue, Mar 15, 2005 at 5:25:00 PM
Attaching Curved walls to underside of Curved Stairs
Wed, Sep 12, 2012 at 12:43:47 PM
curved tread trouble of monopolic stairs.
Wed, Jul 10, 2013 at 5:25:33 AM
90 Degree Curved Stair possible??
Thu, Apr 3, 2008 at 6:54:31 PM
Page generation time: 0.1690
