Forums >> Revit Structure >> Technical Support >> Show model pattern in 3D view
Sat, Dec 6, 2008 at 7:31:14 AM | Show model pattern in 3D view
SMR3
Hello!
I have searched for information in this forum, but I still can't understand why I can't see the brick pattern of wall in 3D view. I drew "Exterior - Brick on Mtl. Stud" wall and skeched that the pattern given to the surface is model type named "Brick 75x225" , the view setting is set to fine, scale is 1:1 shading with edges. Some have achieved, that the pattern shows not only in elevation views, but it doesnt work with this built in wall type. Can anyone tell me please what setting am I missing!
 Regards!
Sat, Dec 6, 2008 at 8:18:13 AM | Show model pattern in 3D view
4 Stars: 205 Votes
Hi, see the video: http://screencast.com/t/pDHOJVtgLvQ
Sat, Dec 6, 2008 at 8:27:57 AM | Show model pattern in 3D view
SMR3
Wow.. this one was cool.. i mean, the Jing thing... I will record my screen, wait a minute please..
Sat, Dec 6, 2008 at 9:04:41 AM | Show model pattern in 3D view
SMR3
Well.. I recorded with CamStudio but cant attach it here... Right now I'm upploading in Jing, I hope it will work out, only jet I dont know where I will get the link to post in here..
The problem is, that the pattern shows only in the elevation views. I can rotate the wall in 3D as I want and look from which side I want, but pattern isnt visible..
Sat, Dec 6, 2008 at 9:16:39 AM | Show model pattern in 3D view
SMR3
Well... here it is
http://screencast.com/t/IcnkBhRRtn
Sat, Dec 6, 2008 at 9:22:24 AM | Show model pattern in 3D view
4 Stars: 205 Votes
Well, very strange, did you ZOOM to the wall in 3D view and check??? can you upload this file with that wall here so i can take a look??
Sat, Dec 6, 2008 at 9:37:04 AM | Show model pattern in 3D view
SMR3
I zoomed.. but nothing..
Sat, Dec 6, 2008 at 9:38:51 AM | Show model pattern in 3D view
SMR3
Something strange is happening with the attaching here.. I attached in previos message file named wall.rvt, but I can't see it attached.. I'll try again..
Sat, Dec 6, 2008 at 9:41:02 AM | Show model pattern in 3D view
SMR3
This simple file is more than 2MB even when commpressed..
Sat, Dec 6, 2008 at 9:58:31 AM | Show model pattern in 3D view
4 Stars: 205 Votes
The problem was solved, it's in the 3D view in the VG-Walls-Surface patterns are turn Off the "Visible"...
Sat, Dec 6, 2008 at 9:59:56 AM | Show model pattern in 3D view
SMR3
I couldn't find where I can mark this thread as resolved, but it is now. For everyone to know, the problem was that under Visibility graphics - Walls - Projection/Surface Patterns - fill pattern graphics, the visible check box wasnt checked.
Sat, Dec 6, 2008 at 10:01:16 AM | Show model pattern in 3D view
SMR3
Trying to show stone on both elevations and model view
Tue, Sep 11, 2007 at 2:24:12 PM
How Do I Make My Fill Pattern Show In 3D View
Tue, Jan 13, 2009 at 2:35:22 PM
Question About Model Pattern
Tue, Feb 19, 2013 at 2:40:21 PM
Model pattern override
Wed, Nov 10, 2010 at 3:50:54 PM
Help- floor pattern not showing up in plan, only model??
Sat, Apr 1, 2006 at 8:56:46 AM
Page generation time: 8.7653
