16 Users Online (14 Members):
Forums >> Community >> Newbies >> help with sheet layout
34 Posts No Rating |
When I send a drawing to the sheet in readiness for plotting it leaves the title of the drawing on the sheet(ie it might say east elevation or 3-D) when i just want the image on the sheet without annotation. Could anyone out there advise how to lose the text ? Thanks
J12 What i think you are trying to do is what we call placing a view on a sheet. If you want the view without the view title you have two choices. 1. click in the view and then edit the properties of the view. duplicate and make a view with out the title. You do this by just unchecking the show title box in the properties dialog. 2. click in the view then right click on the title and hide view. If you do the second you can turn the title back on by using the lightbulb at the bottom. I recomend the first option. It allows you to alter the view while the title is not visible. HTH John
Click on the view and then 'Viewport - No title', on the top left.
tim, I had to create that viewport. J12 couple notes now that i'm working on a machine with revit. Edit the viewport (not view). This is in the upper left corner, like tim said, duplicate, and where it says show title "No". then use this viewport. If you already have a viewport with out a title then you're already there. John
thank you tim and jarosa i will try over weekend and see if i can sort this out thanks once again jonathan, manchester, england
RVT to DWG export page layout settinigs |
Fri, May 11, 2012 at 3:31:01 PM
Drawing Sheet Box around layout? |
Sat, Dec 3, 2011 at 5:02:34 AM
Layout sheet - project status notification. |
Mon, Sep 28, 2015 at 8:56:57 AM
Date on sheet |
Tue, Mar 9, 2010 at 5:12:32 AM
Title Sheet text sent to back? or transparent? |
Wed, Mar 4, 2015 at 3:25:00 PM
