Forums >> Revit Building >> Technical Support >> Some objects appear to be Grey
Sat, Dec 6, 2008 at 12:27:49 AM | Some objects appear to be Grey
yiliboxer
Sorry if this is a double post, but I couldn't find any answers in the forum that were helping.  I have Revit Arch 2009 and some of my materials i made in Sketchup are grey.  I went into the "object styles" and mapped images/colors to the correct layers of the sketchup file...but they still seem to be grey.  i messed with the "phase filter" and "phase" settings, but still with no luck.  Than again, im not exactly sure how the phase filter works...im still a newbie to Revit.  Thanks for your help,
yiliboxer
Sat, Dec 6, 2008 at 8:51:58 AM | Some objects appear to be Grey
4 Stars: 205 Votes
Hi, see the video: http://screencast.com/t/SqODpNqh5k
Sat, Dec 6, 2008 at 3:50:21 PM | Some objects appear to be Grey
yiliboxer
SWEET!!! THanks Typhoon... It seems you really went out of your way... I can't tell you how much I appreciate your help!!!  I didn't realize Revit added it's own layers or "Render Materials."  Anyways thaks again!
Chad
Sun, Dec 7, 2008 at 1:52:00 AM | Some objects appear to be Grey
yiliboxer
Hey Typhoon:
Another question for you... in your video when you click to change a material and click "apply" it instantly shows you if that material was applied or not.  When I do it it does nothing and i have to render after each time to see if the material was applied or not.  Is there a setting you can change so I can see if the material is applied in just the line weights?
Thanks ahead of time,
Chad
Sun, Dec 7, 2008 at 6:01:33 AM | Some objects appear to be Grey
4 Stars: 205 Votes
It's because in 2009 you must see (like in the image) if you have check the button "Shading-Use Render Appearance For Shading" don't show the color because revit change by default the Grey color, but when you choose the material (texture, and you pick in the apply the model change to the color of the material...
Thu, Apr 9, 2009 at 2:00:45 PM | Some objects appear to be Grey
lpnoble
I tryed to see the Screencast but the URL did not work, is it still available? I need to solve this issue and I am sure this video holds the answer.
 Please
 Please
 Please
Thank you!
Thu, Apr 9, 2009 at 2:48:42 PM | Some objects appear to be Grey
4 Stars: 205 Votes
Try this before: http://www.revitcity.com/forums.php?action=viewthread&thread_id=15792
Thu, Apr 9, 2009 at 9:05:55 PM | Some objects appear to be Grey
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi lpnoble, this is an explanation I did for a guy who sent me an e-mail a few weeks ago about this topic, hope it helps you too.....It works with .3ds models but with sketchup models as well.
Before nothing, sometimes you'll notice that not all .3ds files can be imported into ACAD because of their geometry. So what I do is that I always import the .3ds models into Sketchup Pro (or open your .skp models there) and then I export them as .dwg files.Once I've opened the .dwg in ACAD, I begin with the second step which is to "paint" the objects by colors depending on their "category' (blue for the glass, green for the leaves, brown for the  branches and so on). Well, after you've "painted" your object, I proceed to scale it and then ALWAYS move it to the point 0,0,0----check this in all views-----purge and save. Now you are ready to import it into Revit (make sure to create a family depending on the object you are importing, i.e. entourage for cars, planting for trees, etc). In Settings--Materials..., you'll notice that all materials are with names like Render Material 123,123,123 for example, so they are the colors that you previously put in ACAD to the object and now you'll assign with materials. Go to Render Appearance and choose the material you want. Now you are able to render it.....
Edited on: Fri, Apr 10, 2009 at 10:45:44 AM
Fri, Apr 10, 2009 at 1:25:22 PM | Some objects appear to be Grey
4 Stars: 205 Votes
Try this: http://www.megaupload.com/?d=RQ2KIDG0
I don't know if this is the right video, but i think so....
Edited on: Fri, Apr 10, 2009 at 2:19:32 PM
Fri, Feb 24, 2012 at 12:33:02 PM | Some objects appear to be Grey
aysh
hey typhoon can u send me the link of the video. both the videos doesnt exist now n i am experincing the same prob of rendering the sketchup components in revit. i hv attached the sketchup component that i am trying to render. its not just one i hv diff furnitures to do Sad pls help its urgent
Sat, Feb 25, 2012 at 5:54:47 AM | Some objects appear to be Grey
#11
4 Stars: 205 Votes
Sorry but the first video was created in 2008 and it's gone, the second one was saved in Megaupload... gone too
Take a look at this old thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=15792
Mon, Feb 27, 2012 at 8:39:24 PM | Some objects appear to be Grey
#12
aysh
i did see tht thread before asking for help. even then i am not able to sort out the prob. it will be nice if u send me some video link it will help me understand better..plsssss
Grey items!
Sun, Jul 11, 2010 at 7:48:51 AM
Draw order furniture/walls
Wed, Mar 29, 2017 at 11:07:14 AM
White ceiling paint (and other white objects) Rendering "GREY"
Wed, Sep 27, 2006 at 11:52:47 PM
Objects/Components render GREY?! :(
Mon, Jun 23, 2014 at 2:22:22 PM
Yes/No Parameter when checked in Grey
Wed, Jan 12, 2011 at 4:44:35 PM
Page generation time: 0.1142
