Forums >> Revit Building >> Technical Support >> Titleblocks & Design Options
Fri, Dec 5, 2008 at 4:37:09 PM | Titleblocks & Design Options
bradleymatthew
Is there a way to associate titleblocks with design options?  I have several design options that create several of the same sheet - in a perfect world those additional sheets would go away with everything else once that design option has been selected.....thoughts?
Bradley
Mon, Dec 8, 2008 at 9:07:22 AM | Titleblocks & Design Options
Your post is not very clear....   You can control design options through your view VG.  So you can activate the view, turn on DO #1 and print, activate the view again and do the same for DO#2 ...etc.  You could also create multiple sheets with copies of the same view but with the correct DO set.  Each sheet would have to have a different identity ... but I would think you would want that anyway.
Mon, Dec 8, 2008 at 10:04:31 AM | Titleblocks & Design Options
coreed
coreed Avatar
4 Stars: 16 Votes
as far as i know there is no way to create a relationship between a Design Option and a sheet.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Dec 8, 2008 at 2:06:33 PM | Titleblocks & Design Options
bradleymatthew
I have the views set up with the correct DO - that's obvious.  What i want is for the sheet to go away along with the 'unwanted' views - that way my sheet index will automatically update itself too.  I know i can set my sheet index to correspond with the different DO's, I just think it would be easier to remove the old sheets with the DO.....
Bradley
Levels & Design Options
Tue, Jul 25, 2006 at 8:24:11 AM
Design options issues
Thu, Mar 2, 2006 at 10:35:31 AM
Design Options
Wed, Dec 24, 2003 at 10:33:51 AM
design options tied to other objects (version 2008)
Tue, Apr 1, 2008 at 6:17:36 AM
Text In Design Options
Fri, May 28, 2010 at 3:25:07 PM
Page generation time: 0.5099
