Forums >> Revit Building >> Technical Support >> linked file line weights
Fri, Dec 5, 2008 at 10:00:43 AM | linked file line weights
mpp0117
I have been struggling with a column grid file I have linked into my central file. For some reason the columns appear with a very heavy line weight. When I go into my object styles (in both the link file & central file) the columns are set to a very line weight. What do I need to do to be able to adjust the line weights of a linked file?
Fri, Dec 5, 2008 at 3:34:10 PM | linked file line weights
tim123
4 Stars: 19 Votes
How does the column display in the parent drawing, and what type of column is it?  You may need to edit the family to change the line type.
Linked File line weights
Thu, Feb 2, 2012 at 1:08:00 PM
How to match .CTB line weights with Revit
Fri, Dec 5, 2008 at 4:11:55 PM
Linked File Line weight is way off
Tue, Aug 21, 2012 at 7:00:06 AM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Page generation time: 4.7750
