Forums >> Revit Building >> Technical Support >> Errors when importing sketchup model into mass
Fri, Dec 5, 2008 at 7:22:42 AM | Errors when importing sketchup model into mass
Boydy
5 Stars: 3 Votes
Hi Folks, I'm wondering if anyone can shed some light on something for me.
 I'm trying to import a sketchup model into Revit 2009.  I create a new mass, but when I try to import the skp file, it just says 'can't open c:/house.skp'
 Has anyone come across this problem before or has any suggestions?
thanks, Gareth
Fri, Dec 5, 2008 at 7:31:00 AM | Errors when importing sketchup model into mass
4 Stars: 205 Votes
No, what i do with Sketchup models is First Export 3D to DWG then in REVIT import DWG...
Fri, Dec 5, 2008 at 7:46:37 AM | Errors when importing sketchup model into mass
Boydy
5 Stars: 3 Votes
I'm afraid I don't have sketchup pro, so i can't export to dwg
Fri, Dec 5, 2008 at 6:07:41 PM | Errors when importing sketchup model into mass
jdam
jdam Avatar
Hey Typoon...when you export the skp model to dwg, are we then able to assign properties to the elements? i.e., walls are concrete, roof is wood?
Sat, Dec 6, 2008 at 5:24:14 AM | Errors when importing sketchup model into mass
4 Stars: 205 Votes
What i do is assign colors to the elements then when i import to Revit i go to materials and change those colors to the materials i want...
Mon, Dec 8, 2008 at 10:17:47 AM | Errors when importing sketchup model into mass
jdam
jdam Avatar
Cool bro. Thanks for the info.
problems importing sketchup
Thu, Nov 24, 2011 at 4:10:19 AM
Wall Roof Join Error with Sketchup Mass
Wed, Jun 24, 2009 at 4:28:00 PM
Sketchup model becoming an adaptive component
Tue, May 21, 2013 at 8:02:11 AM
Importing Sketchup into Revit
Fri, Nov 5, 2010 at 10:57:40 AM
12
Manipulating sketchup objects in Revit
Tue, Jul 17, 2007 at 9:24:33 AM
11
Page generation time: 0.5334
