Forums >> Revit Building >> Technical Support >> RPC, assetlibrary.fbx... ummm... help?
Thu, Dec 4, 2008 at 6:15:37 PM | RPC, assetlibrary.fbx... ummm... help?
OSU0034
We have created several RPC files using ArchVision's free utility.  The problem is that we can't get them to come into Revit's render library.  When we try to add a new Family Type to (for instance) RPC-male.rfa, we get the list of files that is included with the isntall disk, but none of the RPC files that we've created show up as one of our options.  My best guess is that it has something to do with the assetlibrary.fbx file.
Basically, no matter where we put our .rpc files, Revit can't see them.  I think I've searched the forums pretty rigorously (revitcity, augi, autodesk, google) and haven't found anything that works.  I know there are geniuses out there who can do this, can you put the method in writing?
Fri, Dec 5, 2008 at 4:49:30 AM | RPC, assetlibrary.fbx... ummm... help?
4 Stars: 205 Votes
Ok, put the RPC's in the same folder of the others, but you must CHANGE THE NAME, in 2008 there is no problem with this but in 2009, if you check the name of RPC's in the folder you can see they allways start with "ARCHVISION.......", so, change the name of your new RPC to START with ARCHVISION<name you want>.RPC, i think this solve your problem....
Fri, Dec 5, 2008 at 9:31:16 AM | RPC, assetlibrary.fbx... ummm... help?
OSU0034
Hmm.  That's insteresting.  Thanks Typhoon.
Fri, Dec 5, 2008 at 9:33:59 AM | RPC, assetlibrary.fbx... ummm... help?
OSU0034
Is there a way to get the RPC files to read from our network server instead of just from our local PCs?  That was another cause of this problem.  We renamed the file to have "Archvision" in front, but still couldn't see it on our network drives.  Then when we stuck it onto one of our local machines to render it, it worked.  It's a temporary solution to our overall goal of putting all of our RPCs on the network so that everyone can render them.
Fri, Dec 5, 2008 at 9:45:22 AM | RPC, assetlibrary.fbx... ummm... help?
4 Stars: 205 Votes
Network?? I don't know, I don't work with a Central file... I know this work in local because that what i do when i install 2009 months ago and "put" the Olders RPC to 2009...
Edited on: Fri, Dec 5, 2008 at 9:46:36 AM
2009 RPC files
Thu, Sep 9, 2010 at 2:47:12 PM
Rpc Creator made Rpc can't load
Wed, Oct 24, 2012 at 5:12:32 PM
Revit 2009 to FBX Import into MAX 9?
Wed, Jan 21, 2009 at 1:12:22 PM
Exporting FBX file from Revit to 3Ds Max
Wed, Sep 30, 2020 at 1:36:49 PM
RPC PRoblems
Thu, Nov 17, 2011 at 7:48:35 PM
Page generation time: 1.6018
