21 Users Online (19 Members):
Forums >> Revit Systems >> Technical Support >> recepticle with two circuits how do I tag both? help!!
have created a counter receptacle (electric) with two power connectors (because each outlet is on a separate circuit). I can hook it up fine. however, when I tag it I can't find how to display both circuits in the tag, or at least tag each circuit separately (still on the receptacle)
basically I have outlet plugs in a kitchen where the top plug is on one circuit and the bottom one is on another circuit. when I go to label the I cant
Don't know if this will help much or not, but a lot of times if I copy/paste an element on top of another element of the same... I get a message saying that this may reflect the wrong count in scheduling resulting in a double count. You might try Copy to Clipboard/paste in same place... see if that allows you to tag and schedule both
Multi-wire homerun tag out of order |
Fri, Dec 9, 2011 at 10:18:57 AM
Revit Architecture 2013 Electrical Circuits |
Thu, Jul 11, 2013 at 7:27:01 AM
Is there a way to show switch circuits in Revit MEP 2011 |
Thu, Mar 17, 2011 at 5:17:45 PM
One light fixture, two circuits? |
Mon, Jul 14, 2008 at 9:18:24 AM
Electrical Circuits - odd and even number |
Wed, Sep 22, 2010 at 1:16:55 PM
