Forums >> Revit Building >> Technical Support >> DETAIL GROUP: INCONSISTANCIES w-PLACEMENT of NOTES
Thu, Dec 4, 2008 at 10:53:17 AM | DETAIL GROUP: INCONSISTANCIES w-PLACEMENT of NOTES
rquist
Why do I get inconsistancies when placing a note saved as a detail group? I didnt' think a screen shot would clarify any better my question so hopeully the following descriptions will suffice. Sorry for the lengthy script.
When I place them in an activated viewport they all place properly meaning that they all place with the correct text.  When placed on a sheet with a deactivated viewport they place with a completely different default set of notes.  In all cases, whichever note I place on the sheet w-deactivated view it defaults to the same body of notes.
or
When I place them on a sheet with a deactivated viewport they all default to a different body of notes.  No matter what detail group note I place it defaults to the same different body of notes.  In all cases the different body of notes is a multi-line deck specification note.  When I activate the view on the sheet, it places correctly with the proper text.
or
in other words;  I have my notes saved as detail groups.  Whenever I place any one of 50 simple notes in an activated viewport it places properly. For instance, my note "FLAT CEILING" or "STOVE" or "6" FNDN WALL", etc. places with the same exact text in the activated view, but places with a completely different set of notes on the same sheet the the
Mon, Dec 8, 2008 at 8:37:37 AM | DETAIL GROUP: INCONSISTANCIES w-PLACEMENT of NOTES
I have found that Revit has some strange ways of handeling items in model vs drafting or "paper space" views.  Sometimes you can't even copy paste from one view to another.  It seems that Revit makes some associations between your text and the model elements the text might be pointing to.
Linked file model missing attached detail group
Mon, Aug 17, 2009 at 8:26:38 AM
Adding text notes to a detail
Mon, Dec 10, 2007 at 11:55:09 AM
hidden line default upon placement of group detail
Mon, Dec 8, 2008 at 8:40:31 AM
Detail Group Partial Visibility
Fri, Jul 15, 2016 at 10:37:44 AM
Notes families or links to several files
Thu, Dec 21, 2006 at 12:27:05 PM
Page generation time: 0.2456
