Forums >> Revit Building >> Technical Support >> Wall Cleanup Problem
Thu, Dec 4, 2008 at 4:56:22 AM | Wall Cleanup Problem
bhw71
I am a bit of a newbie to Revit having just finished a 3 day introduction course.
I have come across the attached problem. My instructor on the course was also unable to help so I am turning to you helpful folks in hope that someone can help.
The problem occurs when trying to intoduce a recess in a wall, in this case a service void between communal lobby and an apartment. If the recess depth is less than the overall wall width the corners do not clean up properly as shown on the attachment.
Can anyone offer some words of wisdom on this?
 Thanks in advance
Thu, Dec 4, 2008 at 5:01:39 AM | Wall Cleanup Problem
4 Stars: 205 Votes
Hi, did you try to TRIM beetween those two walls? Did you use the "Join Geometry" and "Wall Cleanup"????
Thu, Dec 4, 2008 at 5:05:46 AM | Wall Cleanup Problem
bhw71
Thanks for the quick response Typhoon.
Yes I have tried trim, join geometry and wall clean up but no joy with any of these.
Thu, Dec 4, 2008 at 5:11:37 AM | Wall Cleanup Problem
Dafpfy
3.5 Stars: 11 Votes
http://www.revitcity.com/forums.php?action=viewthread&thread_id=13873
Revit doesnt handle those situations that good,
try using the disallow join in combination with the join geometrie options,
disallow join can be found when you rightclick on the little bleu dot on the wall end,
in the situation above i ended up adding the two middle walls in with a disallow join on there ends and cleaning it up with masking regions.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, Dec 4, 2008 at 5:26:04 AM | Wall Cleanup Problem
bhw71
Thanks for the suggestion Dafpfy.
Still no joy though.
Thu, Dec 4, 2008 at 5:39:14 AM | Wall Cleanup Problem
4 Stars: 205 Votes
Hi again, try this, pick in the "Left" wall, pick in "Disallow join" and "stretch" that wall to the Left until they don't touch, then try with trim....
Custom Wall Cleanup tool
Mon, Jan 18, 2016 at 2:12:14 PM
Wall Floor Intersection Cleanup
Thu, May 4, 2006 at 12:06:45 PM
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008
Wed, Sep 3, 2008 at 12:33:09 AM
Wall Footing Cleanup - A Problem
Fri, Jun 25, 2010 at 3:46:12 PM
wall cleanup radius
Thu, Aug 9, 2007 at 4:56:14 PM
Page generation time: 2.5136
