Forums >> Revit Systems >> Technical Support >> Placing Rebar in a CMU wall
Wed, Dec 3, 2008 at 5:03:24 PM | Placing Rebar in a CMU wall
Userfile
I am trying to create a CMU wall with #5 rebar spaced 32" OC vertically and continuous in the bond beam at the top course. I want to be able to see the rebar in elevation or 3d wiews, as well as plan and section. What steps do I go through?
Fri, Dec 5, 2008 at 5:18:38 AM | Placing Rebar in a CMU wall
4 Stars: 205 Votes
You can use "wall sweep" or "Create-In-Place", or create a "Generic Wall face based Family" or "Generic Face Based Family" to create that, can you post some images of what do you really want to clarify the problem???
Edited on: Fri, Dec 5, 2008 at 5:20:03 AM
Rebar on Wall Based Family Questions
Mon, Dec 14, 2009 at 4:49:24 PM
CMU wall reinforcement and detailing
Mon, Nov 22, 2010 at 1:32:03 PM
Placing Rebar/Strand in Walls
Fri, Apr 10, 2015 at 4:04:48 PM
CMU Wall
Thu, May 7, 2015 at 12:15:47 PM
placing curtain walls in walls
Sat, Jan 9, 2010 at 3:36:34 AM
Page generation time: 1.2173
