13 Users Online (11 Members):
Forums >> Revit Building >> Tips & Tricks >> Easy Stone Hatch patterns (Stone CAD)
1. Go to this website http://www.culturedstone.com/stonecad/getstonecad.asp 2. Download the program 3. In Revit go to settings/fill patterns/model 4. Click on new pattern 5. Click on custom pattern 6. go to the place on your computer where you saved the StoneCAD program follow the path below once in stone cad (This is the path to it on my computer, yours might be different but from cultured stone it should be the same. C:\Program Files\Cultured Stone\StoneCAD 5\Application\resources\assets\hatch\revit_Model 7. Pick th one you want. It is a little hard because you cannot see the pattern as you pick it They also have texture maps at C:\Program Files\Cultured Stone\StoneCAD 5\Application\resources\assets\jpgTextures I hope this helps AAron
Thanx aaronkennedy for this info.
“Learning never exhausts the mind.” — Leonardo Da Vinci
Stone Hatch Patterns - Looking for a good source. |
Sat, May 4, 2013 at 4:59:24 AM
Best approach for Stone Veneer component "hatch pattern"? |
Mon, Sep 29, 2025 at 7:21:02 PM
Stone Hatch patterns |
Fri, May 3, 2013 at 6:11:31 PM
How to Import Hatch Patterns |
Thu, May 31, 2012 at 1:16:12 PM
Stone Walls, Stone Veneer, etc |
Fri, Oct 6, 2006 at 8:21:58 AM
