14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Accent panel that cuts through 2 walls
78 Posts No Rating |
RAC 2008 I am a relative RAC newbie. I used it awhile ago, but only for student projects. Now I am using it in an office environment which is totally different. What I am trying to do is create an exterior accent panel above a window that can cut through two walls (the one is it being placed on as well as the one above). The panel represents a material change. I made it as a Wall - Component but for some reason it will only cut through the one wall that it is placed on. Any suggestions?
Use join geometry ... should work.
So I click join geometry then click one wall and then the other? Because after selecting one wall, the other wall is not able to be selected.
Exterior accent colors |
Tue, Dec 9, 2008 at 9:28:43 AM
Door that cuts a curtain and a normal wall at the same time |
Sat, Jun 1, 2019 at 7:33:18 PM
Window family that cuts walls? |
Tue, Sep 2, 2008 at 12:41:38 PM
panel walls - getting walls to subdivide automatically with joints already in. |
Wed, Nov 24, 2010 at 6:22:27 PM
composite panel walls |
Fri, Feb 25, 2011 at 1:32:37 PM
