Forums >> Revit Building >> Technical Support >> deleting curtain system once it is in place
Tue, Dec 2, 2008 at 11:29:46 PM | deleting curtain system once it is in place
balletbabe806
I wanted to edit the mass that I created by sweep blend in Revit Arch 09...I added a curtain system from the massing tab...
Is there any way to remove the curtain system so I can go back and edit the solid??
Wed, Dec 3, 2008 at 5:22:43 AM | deleting curtain system once it is in place
4 Stars: 205 Votes
Hi, you don't need to remove your Curtain system, you can pick in the mass, edit them, change what do you want and finish, then pick in the curtain system and in the menu bar you have a button "Remake", this will adjust your curtain system to the "new" mass shape....
Wed, Dec 3, 2008 at 8:48:26 AM | deleting curtain system once it is in place
balletbabe806
yeah, thanks Smile i figured it out.. i have to change the view/graphic overrides...i just created a 3d view with just the mass...and then one with just the curtain wall.
Another question: My building (performance space) has ribbons of glazing (arching from one wall to the ground.) There are 4 of them.  I created them individually. Now they need to be rotated and put in place, attatched to the wall etc. Is there anyway to copy the masses, the voids and the curtain wall, so that I would be able to edit the individual ribbons once in place?
no matter how i copy, once I copy Revit can't access the sweep blend..so it won't let me edit it and it essentially becomes a static object...should i group the mass and the voids and the curtain wall and then copy?
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
Curtain System Problem
Sat, Sep 16, 2006 at 5:09:13 PM
Curtain system from mass - Revit 2014
Fri, Jun 17, 2016 at 12:20:49 PM
Timber curtain wall system
Wed, May 8, 2013 at 7:40:34 AM
Curtain System by Face
Tue, Nov 8, 2005 at 9:07:18 PM
Page generation time: 0.4533
