Forums >> Revit Systems >> Technical Support >> Calculating CFM on Return Ductwork problem
Mon, Dec 1, 2008 at 1:43:37 PM | Calculating CFM on Return Ductwork problem
Broken
Revit seems to choke on calculating total CFM when you tap more then once into a duct.  IE: I have a main return air trunk and I have 2 branches tapping into it before it changes size.  The CFM totals 0 out.  But the CFM totals down the line of the taps are correct.  Is there a solution to this? Or maybe something that I am missing?Thanks!
Load Calcs not using CFM/SF?
Tue, Nov 20, 2012 at 11:07:27 AM
Shading Ductwork and Air Terminals on plan
Tue, Oct 19, 2010 at 3:08:32 PM
Will a change in cfm update ductsize?
Mon, Mar 14, 2011 at 7:58:47 AM
Ductwork connected to air device displays flow in one model but not another
Fri, Nov 15, 2013 at 7:33:41 AM
Return Air systems help? Please
Tue, Feb 9, 2010 at 11:42:41 AM
Page generation time: 1.1805
