Forums >> Revit Building >> Technical Support >> Where is the Line Patttern info stored.
Sun, Nov 30, 2008 at 8:47:01 AM | Where is the Line Patttern info stored.
DaveF
Hi
Rather than type in all the line data in I was thinking I could reformat my old acad.lin to suit revit.
I looked in the Registry but couldn't find it. Is it stored within each rvt/rte file?
Is seems strange that you can use Acad hatch pattern files, but not linetypes :-(
Hope you can help
Cheers
Dave F.
Sun, Nov 30, 2008 at 9:14:47 AM | Where is the Line Patttern info stored.
read your help - line patterns... it tells all that there is.
Sun, Nov 30, 2008 at 11:17:05 AM | Where is the Line Patttern info stored.
coreed
coreed Avatar
4 Stars: 16 Votes
i don't think line patterns are read from a file as in Autocad. they are just simple dots, dashes, and spaces only. ????
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Nov 30, 2008 at 5:54:28 PM | Where is the Line Patttern info stored.
DaveF
I did read the help file, but as we all know about the Revit documentation, it rarely tells the whole story & leaves a lot to be desired.
Cheers
Dave F.
Mon, Dec 1, 2008 at 9:00:57 AM | Where is the Line Patttern info stored.
Well, in this case, REVIT HELP tells you that the linetypes are stored with the project file and then it goes on to tell you how to make them...   I don't believe it is any clearer than that and it does tell you all.
Please learn to use REVIT's help .... it is not like AutoCAD.  It is much more complete and is really a help!
Are line patterns stored in a family?
Fri, Sep 3, 2010 at 6:12:53 PM
Where in Revit 2015 are Patterns stored?
Fri, Jan 8, 2016 at 1:25:59 PM
Nested families stored in project - Not in family
Mon, Jun 20, 2011 at 4:21:12 PM
patttern downloads
Thu, Jun 22, 2006 at 9:48:14 AM
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
Page generation time: 3.7709
