13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> topo goes through building
3 Posts No Rating |
I have a building that is split level-sitting on a slope...when i add my topograpy with the points...it goes through my building in the 3d views. Is there a way to make the topography stop at the building edges?
Ok cljahnke, if I understand well your doubt, you want to "cut" the terrain that goes through your building. Click Site menu-Pad, or on the Site tab of the Design Bar click Pad, then with lines, sketch the contour of your building, click finish sketch, so it will cut the terrain exactly around your building, hope it could help you.
3 Posts No Rating |
Yep! thanks so much! that worked perfectly. I feel silly that I didn't understand that before.
Modify Topo & Building together |
Fri, Jul 13, 2012 at 9:14:09 AM
Topo is struggling |
Tue, Aug 15, 2006 at 9:24:01 AM
Elevation of Topo points |
Tue, Nov 7, 2017 at 10:20:45 AM
Topo surface/Building Pad problems b/w Existing and New Construction phases |
Sun, Feb 6, 2011 at 12:28:27 AM
Modeling Topo After Building |
Fri, Jun 24, 2016 at 11:35:23 AM
