Forums >> Revit Building >> Technical Support >> Foundation Wall attaching to wrong layer
Thu, Nov 27, 2008 at 10:55:45 PM | Foundation Wall attaching to wrong layer
ScopeDrafting
Using Revit Arch. 2009 and am adding a foundation to a cavity brick wall. Outer leaf of brick work extends below inner leaf. On some walls it attaches to outer leaf on others it attaches to inner leaf. I need it to  attach to outer leaf of brickwork every time. I cannot flip the wall because inner and outer are different thicknesses. What am I doing wrong? How do I change the wall or foundation to attach where I want it?
Thanks
Fri, Nov 28, 2008 at 4:42:10 AM | Foundation Wall attaching to wrong layer
4 Stars: 205 Votes
Hi, you can use the "Join Geometry" to clean that, also check in properties of the wall the "Core" position, if you change the "core" the insertion of the wall it's different if this is what do you want...
Offset of the Wall foundation from the wall in Height
Sun, May 12, 2019 at 2:43:15 PM
Foundation attaching to a columns analytical line
Thu, Feb 11, 2010 at 10:53:59 AM
Foundation with layer
Mon, Jan 26, 2015 at 10:24:25 AM
Foundation Wall Profile
Tue, Feb 16, 2016 at 4:35:07 AM
Slab Rigid Insulation
Tue, Nov 20, 2007 at 11:01:32 PM
Page generation time: 1.9159
