Forums >> Revit Building >> Technical Support >> SHELVING SYSTEM
Thu, Nov 27, 2008 at 1:35:34 PM | SHELVING SYSTEM
paulykustomz
paulykustomz Avatar
OKAY SO IM GETTING BETTER WITH BUILDING FAMILIES BUT THE PARAMETERS ARE CONFUSING ME. ALL i WANT IS BASICALLY A SHELVING UNIT WITH 5 SHELVES. i WANT TO BE ABLE TO ADJUST THE HEIGHT OF EACH SHELF. i WOULD ALSO LIKE TO BE ABLE TO CHANGE THE OVERALL DIMENSIONS OF THE UNIT ITSELF (HEIGHT,DEPTH,WIDTH) IF ANYBODY KNOWS WHERE i CAN FIND A GENERIC FAMILY FOR THIS IT WOULD BE GREATLY APRECIATED. OR IF YOU WANT TO TRY THIS IS WHAT  HAVE SO FAR.
Thu, Nov 27, 2008 at 8:50:34 PM | SHELVING SYSTEM
Westview
2.5 Stars: 2 Votes
Have you checked the Downloads tab next to the Forums tab. Look under Division 12 Casework, there is a tall cabinet with  adjustable shelves that looks like what you are looking for. If not it can be modified easily.
Thu, Nov 27, 2008 at 9:33:40 PM | SHELVING SYSTEM
Westview
2.5 Stars: 2 Votes
Attached is a tall cabinet with Adj. Sh. The shelf spacing needs to be less than the cabinet height.
Fri, Nov 28, 2008 at 9:32:55 AM | SHELVING SYSTEM
paulykustomz
paulykustomz Avatar
thank you I added instance parameters and it worked out
Lighting in shelving units
Sat, Nov 19, 2011 at 9:16:41 AM
Yes/No paramter controlled by two different types of paramters
Thu, Mar 13, 2014 at 11:58:39 AM
New system type
Thu, Sep 16, 2010 at 3:58:35 PM
Scheduling Nested Families
Mon, Mar 9, 2020 at 11:15:10 AM
Websites for Revit Families
Tue, Mar 5, 2013 at 5:38:47 PM
Page generation time: 0.3029
