Forums >> Revit Building >> Technical Support >> Groups VS Nested Families
Wed, Nov 26, 2008 at 3:32:42 PM | Groups VS Nested Families
JHectorne
RAC 2008
Hello and Happy Thanksgiving.  I am in the process of getting commonly used components together for quicker model building, and I was wondering what are the pros and cons of using groups over nested families and vice versa.  I'm not really seeking a definitive answer, just looking for opinions.  I have made both, and the biggest difference I can see (with my limited knowledge) is that editing a nested family opens a new window, whereas groups are edited right there in the model.
Thanks for your input, and don't eat too much tomorrow.
Jim
"You've got to remember that we are just simple operators.  We are people of the web.  The common clay of the new millenium.  You know...Newbies."
Wed, Nov 26, 2008 at 8:25:44 PM | Groups VS Nested Families
mtyp
nested families are really good for family components.  They can lead to scheduling woes if they aren't managed.
A good example of that would be a door family with 3 other door families nested in (door leaf, jamb and hardware)
Groups can have system families (walls, etc) that will interact with objects outside the group.  And yes they edit in place.
One of my new favourite techniques when working with groups is to select and temporary isolate the group then work on it, gives you the best of both worlds.  the interacting and islotated elements.  My other favourite is Copy to Clipboard then Paste Aligned -> Select Levels by Name.  Instant service cores, lifts and stairs.
Thu, Nov 27, 2008 at 12:51:14 PM | Groups VS Nested Families
KingRevit
4 Stars: 12 Votes
rember groups effect the performance a lot of your modle i try not to use them unless there is a lot of time savings as in hospital design as you have so many standard rooms.
Tue, Dec 2, 2008 at 11:51:10 AM | Groups VS Nested Families
JHectorne
Thank you for your responses.
We do custom residential design.  We are looking into creating basic kitchen and bathroom cabinet layouts; since most of our work is residential there won't be a great deal of repetition inside a single project.  We just want something we can pop into the model and edit fairly quickly.  Adding each piece of cabinetry, countertops and appliances, all one at a time, is very time consuming.
We're just looking for a quicker way.  I have seen some nested families, such as the Kitchenette, on the Adesk Web Library, and it seemed to work ok.  Is this the best solution to our situation?  I do like grouping as I said before, because you can edit it right there without going into another file.
Anyway,  just wondering.  Thanks again.
Jim
Tue, Dec 2, 2008 at 11:58:07 AM | Groups VS Nested Families
Rather than using groups - have your standards in one file - open this with your project & use cut & paste.
Mon, Apr 20, 2009 at 10:49:07 AM | Groups VS Nested Families
dfitzladdy
5 Stars: 3 Votes
i was wondering this same question - whether to use groups or families. in my project i have a model group that is repeated in several different spots, but not enough that I would think I needed it to be a family instead.  However, pieces and parts of this model group are misteriously thrown off to the side of the site - way off to the side. It's really strange, and it keeps happening.  I'm not sure if it's a problem with groups, but i'm switching this particular group into a family so hopefully that will solve the problem.
Can Revit Families and Groups be updated automatically?
Fri, Nov 17, 2017 at 6:47:01 AM
Locking nested families?
Wed, Aug 27, 2008 at 12:23:09 PM
13
nested families do not cut
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project
Thu, Jan 14, 2010 at 10:21:37 AM
Page generation time: 0.6498
