Forums >> Revit Building >> Technical Support >> SIMPLE SYMBOL why is it so complicated revit 2009
Wed, Nov 26, 2008 at 2:16:42 PM | SIMPLE SYMBOL why is it so complicated revit 2009
paulykustomz
paulykustomz Avatar
im trying to make an annotation to put inbetween two sections. I have tried a bunch of different ways but cant make the dimensions variable. there is a jpeg of whta im trying to make and the revit file im working on does anyone know how I could go about it?
Thu, Nov 27, 2008 at 5:18:06 AM | SIMPLE SYMBOL why is it so complicated revit 2009
puzzle
4 Stars: 10 Votes
when you make any family that is going to be parametric i always start with adding reference planes/lines then add dimensions and parameters. flex these to make sure all is working how you want it. when adding lines constrain them to the reference planes/lines. have a look at what i did to your symbol. i only did the one side. even with the ends of lines, use align to align to the ref line.
hope this helps
Macca
Sunshine Coast
QLD Australia
Thu, Nov 27, 2008 at 10:29:29 AM | SIMPLE SYMBOL why is it so complicated revit 2009
paulykustomz
paulykustomz Avatar
THANK YOU GUYS VERY MUCH i'M STARTING TO UNDERSTAND.
new symbol from 2009 wont load as symbol in 2011
Wed, Jul 6, 2011 at 2:09:39 PM
Simple Dynamic Family
Fri, Nov 21, 2014 at 12:13:15 PM
Weld symbol editing
Thu, Jan 6, 2011 at 9:50:16 PM
Wall hosted familes (simple question)
Tue, Jan 15, 2013 at 2:45:24 AM
Insert North Point Annotation Symbol
Thu, Aug 4, 2011 at 1:04:42 AM
Page generation time: 1.5308
