Forums >> Revit Building >> Technical Support >> Generic Model Materials
Wed, May 18, 2005 at 3:46:52 PM | Generic Model Materials
khillman
Hi, awhile back I created a generic model family within my project to act as facade slats that create a moire on the facade. Now, these slats are generic models, and I am having a problem making them act as wood, because now the lcient decided on what material to make them. I have tried the Object Settings technique for the Generic Models, with no success. Please help. Thanks.
Wed, May 18, 2005 at 4:19:44 PM | RE: Generic Model Materials
TomDorner
4.5 Stars: 25 Votes
Edit your in-place family. Set the material you want for the slats within the family. You may also want to explore using a sweep to produce the slats as it might be easier to do. HTH Tom
Wed, May 18, 2005 at 4:21:52 PM | RE: Generic Model Materials
khillman
the only way i can think of editting the material of the in place family would be to add a parameter. When adding this parameter, and changing the material, still no material when this inplace family is rendered.
Wed, May 18, 2005 at 5:03:38 PM | RE: Generic Model Materials
TomDorner
4.5 Stars: 25 Votes
You have to go deeper into the family. If you used a sweep for instance for each slat, you need to edit that individual sweeps material property. This is why I suggested using the Revit hosted wall sweep instead as it makes the material assignment easier. Tom
Fri, Oct 3, 2014 at 1:53:40 PM
CREATING A SCHEDULE FROM A GENERIC MODEL FAMILY?
Mon, May 11, 2009 at 11:49:38 PM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:18 PM
generic model cutting issue 2016
Sat, Aug 27, 2016 at 7:43:47 AM
Opening in Generic Model Standing seam roof
Mon, Aug 17, 2009 at 9:43:32 AM
Page generation time: 1.0355
