Forums >> Revit Building >> Technical Support >> curved curtain system -diagonal grid system?
Tue, Nov 25, 2008 at 4:08:14 PM | curved curtain system -diagonal grid system?
balletbabe806
I have curtain walls that are curved in section (arching over like a barrel vault spilt down its longitudinal axis) and they have an irregular mullion system (at diagonals)
I can create a curved curtain wall (family) but is there a way to add mullions to the curtain wall ? I cant get it to accept a curtain grid and I need it to have specific panels so I can change the type..
I also created a curved mass object (by using mass sweep) and I added a curtain wall by face....is there any way to make it a smooth curve (not a series of angled planes)?? or a way to angle the grid system that is in place (I know you can angle the grid on a basic curtain walbut that option doesnt exist for the curtain wall by face
Wed, Feb 11, 2009 at 4:24:47 PM | curved curtain system -diagonal grid system?
quinn
From what ive experienced curtain walls apply the glass as flat glass not curved so it requires more panes of glass to resemble what you need..   So to answer your last question the glass in order to curve requires more mullions (add more curtain grids within the curve to see the flat panes of glass follow  towards the curve you made).
Regular grid on Curtain system by face
Mon, Sep 30, 2013 at 2:57:17 PM
Curtain system grid _Rhino to revit
Wed, Jul 3, 2013 at 8:11:53 AM
Curtain system from mass - Revit 2014
Fri, Jun 17, 2016 at 12:20:49 PM
Curtain System on a double curve
Wed, Jun 20, 2012 at 9:13:33 AM
Curtain Grid Problems [ 1 2 ]
Wed, Apr 10, 2013 at 5:57:45 AM
17
Page generation time: 3.1458
