Forums >> Revit Building >> Technical Support >> Attaching Curved walls to underside of Curved Stairs
Tue, Nov 25, 2008 at 3:15:30 PM | Attaching Curved walls to underside of Curved Stairs
OsullivanArchitects
Can anyone help me with this?
Wed, Nov 26, 2008 at 3:52:15 AM | Attaching Curved walls to underside of Curved Stairs
tim123
4 Stars: 19 Votes
David Light had an article on this but I cannot find it.  Basically, create the curved wall and use a void swept blend, with the curve of the wall as the path.  Use cut geometry to cut the wall.
Another method by Mr Spot is described in the tutorial section of this site - see http://www.revitcity.com/tutorials/stair-wall_trimming/
I think the first method is easier, if you are using 2009.
Thu, Mar 31, 2011 at 4:36:52 PM | Attaching Curved walls to underside of Curved Stairs
gabrielisa
Hi, Please can anyone help me on how to attach the top ofa curved wall to the base of a curved ramp? I saw the older posts about attaching walls to a curved stair,and I want to know if it is the same concept i can try. I really will appreciate your help..
Thanks,
Gabrielisa
Thu, Mar 31, 2011 at 5:49:17 PM | Attaching Curved walls to underside of Curved Stairs
thetabest
thetabest Avatar
3 Stars: 2 Votes
Consider using floor to create your ramp?  Not sure this will get the slope/effect desired, but at least you can attack the wall tops to the floor... otherwise use tim123's advice.
Trent Best
Best Systems
the.tabest@gmail.com
Thu, Mar 31, 2011 at 6:55:50 PM | Attaching Curved walls to underside of Curved Stairs
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
place a reference plane along the bottom of the ramp.  Use "attach top/base" while selecting the wall, and click on the reference plane, the wall will extend up to meet it.
Thu, Mar 31, 2011 at 11:03:18 PM | Attaching Curved walls to underside of Curved Stairs
gabrielisa
Thanks, I'll try to use the ramp as floor and modify its slope...hope it work...
Thanks,
Gabrielisa
Wed, Sep 12, 2012 at 11:57:30 AM | Attaching Curved walls to underside of Curved Stairs
vrmoreno3
I just tried this with a stair that is based on an elipse. Picking the bottom of the staor case requried multiple line segments, which the extrision did not like. Each solution I find doesnt seem to work for me.
Wed, Sep 12, 2012 at 12:10:21 PM | Attaching Curved walls to underside of Curved Stairs
Create an in-place void family and use that to cut the wall.
Wed, Sep 12, 2012 at 12:11:09 PM | Attaching Curved walls to underside of Curved Stairs
vrmoreno3
I take it back. I had to trim fillet each line segment together. It only work for one stringer of the staircase and would have to create another "roof" for the other stringer face. Maybe it is becasue the stair is curved and is skewed because of the elipse.
Wed, Sep 12, 2012 at 12:38:26 PM | Attaching Curved walls to underside of Curved Stairs
vrmoreno3
Wed, Sep 12, 2012 at 12:43:47 PM | Attaching Curved walls to underside of Curved Stairs
vrmoreno3
Im not so sure the in place void will work. The front and back side of the stair case, because of the ellipse is making it impossible to
Attaching walls to stairs
Tue, Aug 22, 2017 at 12:20:10 AM
13
Wall projection to underside of curved roof
Thu, Feb 2, 2012 at 5:19:28 PM
Curved Stair - Smooth Underside
Thu, May 3, 2007 at 9:54:55 AM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
CURVED WALLS AND CHANGING THE PROFILE
Thu, Nov 6, 2014 at 7:58:51 AM
Page generation time: 4.3966
