Forums >> Revit Building >> Technical Support >> Different material on same wall type???
Wed, May 18, 2005 at 2:43:37 PM | Different material on same wall type???
jweber
I am very new to Revit, so please forgive me if this has been addressed before (although I couldn't find it). I am working on a masonry building that has two different types of finish color to them. What is the easiest way to change them. Right now my whole building is one color. Can I change just certain walls or is it more difficult than that? Thanks, Jeff
Wed, May 18, 2005 at 3:08:37 PM | RE: Different material on same wall type???
TomDorner
4.5 Stars: 25 Votes
I use two different wall types as that is what they are in real life. You could also split the face of the wall an "paint" in a different finish as well. Both approaches work, but you always have to be thinking longer term. Does each wall type need to be scheduled for accurate material take-off? Or are you just trying to get something out the door that looks correct? HTH Tom
Change material on wall
Thu, Jan 26, 2012 at 7:15:41 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Schedule material mark in schedule type other than material Schedule?
Wed, Jun 22, 2011 at 3:59:07 PM
Material take off - is this a bug?
Mon, Jan 24, 2011 at 8:15:10 PM
material and sq.ft. of the wall (schedule)
Fri, Mar 3, 2006 at 12:12:07 PM
Page generation time: 0.7920
