18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Steel columns do not display in detail view
3 Posts No Rating |
I am having a problem with steel columns not showing up in plan details. My columns begin at the first floor slab and continue in one piece to the roof over the second floor. They show up in first floor plan details - but not in second floor plan details. Any ideas? My short-term solution is to modify my steel to go from 1st to 2nd and another column to go from 2nd to roof.
Are you sure that they are not attached to the floor? This will overide the height set in its properties.
3 Posts No Rating |
Yes. I have checked that.
Do you have them in a ist floor workset?
3 Posts No Rating |
No. They are in a structural workset. I have verified that all worksets are visible in the view. I have also verified that all structural elements are visible in the graphic overrides for that detail view.
209 Posts No Rating |
Open family go to settings-family categories and parameters- uncheck the show family precut in plan view. HTH
hidden steel columns showing as solid |
Tue, Nov 23, 2010 at 12:18:43 PM
Detail View Question - Cannot see columns in a medium or fine view |
Thu, Aug 16, 2018 at 12:50:29 PM
11
timber and steel to have different detail levels |
Fri, Sep 3, 2010 at 8:29:04 AM
LINESTYLE OF HIDDEN STEEL COLUMNS |
Mon, Jan 17, 2011 at 5:25:38 AM
Column disappers in detail view |
Mon, Jan 12, 2009 at 9:35:19 AM
