Forums >> Community >> Newbies >> Help regarding Lighting....
Tue, Nov 25, 2008 at 4:29:29 AM | Help regarding Lighting....
Harjeet
Hi... m a newbie . joined just a few weeks ago. I have learned a lot till now , Thanks to revit city.  now i have taken one excercise but just in the begining m stuck with the lighting. my problem is that the portion where sunlight falls is brighten and the rest is dull. m attaching both the images what i have done and original one i want to make. i have considered the room to be 20' X 20'. help with the camera setting also.
thanks in advance
Tue, Nov 25, 2008 at 5:03:57 AM | Help regarding Lighting....
KingRevit
4 Stars: 12 Votes
im not sure wxactly what your on about, but it may be to do with glass and daylight portals, have youused the daylight portals?
Tue, Nov 25, 2008 at 5:31:27 AM | Help regarding Lighting....
Harjeet
no i havnt used any daylight portals... i dont know how to use them.
Tue, Nov 25, 2008 at 7:42:18 AM | Help regarding Lighting....
rossaftermath
5 Stars: 5 Votes
Its fairly simple.. but it has cost upon render time..
If you are using 2009...
The in your render dialog for the view at hand..
In the quality options scroll down and select edit.
then in that page you will see scroll down to the bottom
and select the daylight portals you wish to allow.. for more look in the revit help menu
render in "custom/specific"
Wed, Nov 26, 2008 at 1:53:26 AM | Help regarding Lighting....
audyr1
4 Stars: 1 Votes
hi!!! m facin a problm wid d lightin part... wheneva i load exterior street lights i.e lamp posts n render it, it doesnt wrk.... i hav chekd d settings... d lights r turned on... hav tried changig d lumens n wattage value.. bt it doesnt wrk... plz hlp me regardin dis....
Wed, Nov 26, 2008 at 8:03:29 AM | Help regarding Lighting....
rossaftermath
5 Stars: 5 Votes
^^^What happens if you create a new 3dview and then render the scene?
I've had the same problem before, thats how i solved it
Wed, Nov 26, 2008 at 12:20:11 PM | Help regarding Lighting....
audyr1
4 Stars: 1 Votes
Thnx mate bt i hav tried dat... is der any settings in light properties like changing its lumens, wattage.. cn u plz tell me wot is d appropriate value of watt n lumens of a street light to get d bst effect... n do i hav to attach a light in d lamp posts or so.. m confused.. hlp me mate... n moreovr d lights in d car also dnt wrk... wot cn i do in case f cars... plz hlp.. hav to make a presentation..
interior lighting for exterior rendering [ 1 2 ]
Thu, Feb 11, 2016 at 2:03:04 PM
16
Electrical/Lighting plan [ 1 2 ]
Wed, May 13, 2009 at 11:27:51 PM
16
Lighting fixture problems
Wed, May 10, 2017 at 9:52:09 AM
13
Lighting
Mon, Mar 2, 2015 at 6:53:44 AM
cove lighting?
Wed, Dec 7, 2011 at 2:23:00 PM
Page generation time: 1.2882
