Forums >> General Discussion >> Wishlist >> Roof Drains
Wed, May 18, 2005 at 2:02:08 PM | Roof Drains
markitekt
I have not been able to find any 3D Roof Drains. I checked Revit City, AUGI and Autodesk Revit websites and could not find. If any of you have found or created any, please upload to the Family Explorer. Many thanks.
Fri, Sep 1, 2006 at 6:42:34 PM | RE: Roof Drains
kshahan
Any luck with that? I could use some 3d roof drains as well.. If I can't find any, perhaps I'll end up making the family...but thought someone has to have done this already. Cheers! Kerry
Wed, Sep 6, 2006 at 8:02:48 PM | RE: Roof Drains
kshahan
I ended up making a roof drain family that can be put into roof plans. There is much room for improvement...but something is better than nothing. So., I kicked it off and uploaded it to the family explorer. I hope someone will use it and make it better. See: Division: Detail Components Category: Architectural Sub Category: Ceilings and Roofs Cheers! Kerry
Mon, Sep 11, 2006 at 11:33:11 AM | RE: Roof Drains
markitekt
For your use, I have created a roof drain family. It is a general 3D form of strainer and clamping ring. It can be found at the following RevitCity location: Division: Detail Components Category: Architectural Sub Category: Ceilings and Roofs PS I also created a thru-wall scupper that can be found in the same location. markitekt
Roof Drains- Architecture 2008
Wed, Sep 19, 2007 at 5:00:03 PM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Flat roof and a curved wall
Tue, Nov 20, 2007 at 9:56:42 AM
Roof Drains
Thu, Apr 9, 2009 at 4:08:44 PM
Page generation time: 3.6406
