Forums >> Revit Building >> Technical Support >> Can you create mirrored walls (shiney reflective ones) with Revit?
Mon, Nov 24, 2008 at 7:41:51 PM | Can you create mirrored walls (shiney reflective ones) with Revit?
GizmoJoe
I am working on a project and have mirrored walls in a gym area. Is there any way to create a reflective mirrored surface with Revit?
Thanks,Gizmo Joe
Tue, Nov 25, 2008 at 12:07:26 PM | Can you create mirrored walls (shiney reflective ones) with Revit?
tim123
4 Stars: 19 Votes
Yes.
Use chrome as a surface finish or create a new material with the reflection settings set to their maximum.
Ceilings, walls and columns are reflective
Fri, May 27, 2016 at 7:59:39 PM
reflective glass on the outside- not reflective on the inside
Fri, Nov 30, 2012 at 7:46:21 AM
Curtain Panel Unexpectedly Mirrored in Project
Fri, Feb 26, 2016 at 1:22:33 PM
Mirrored Families
Thu, Oct 2, 2014 at 12:49:16 PM
Mirror stairs has different layout
Tue, Feb 19, 2013 at 8:24:52 PM
Page generation time: 5.2080
