Forums >> Revit Building >> Technical Support >> Revit 2009 : Area Separation and Mass Room Stacking and Blocking
Mon, Nov 24, 2008 at 2:49:02 PM | Revit 2009 : Area Separation and Mass Room Stacking and Blocking
Hydroglyphic
Is there a way to Lock Area separation lines to a mass? and is there a way to get Area Separation Lines to act like Polylines in Autocad?
I am trying to do Blocking and Stacking diagrams for a huge project, and it has become a pain in the behind to constantly change, and update the Area lines.
Mon, Nov 24, 2008 at 3:29:50 PM | Revit 2009 : Area Separation and Mass Room Stacking and Blocking
afc4
3 Stars: 3 Votes
You can lock the lines to the mass, When you are creating the room or area seperation lines you will get the pad locks which allow you to lock the lines to the face of the mass. if you dont see them use the align tool and line them up that way. And theres no way that i know of that you can make them polylines.
Mon, Nov 24, 2008 at 4:12:28 PM | Revit 2009 : Area Separation and Mass Room Stacking and Blocking
Hydroglyphic
When I lock The Area lines to the mass, then try to stretch the mass later, I get an error that the element can no longer be joined and I have to unjoin them.
Mon, Nov 24, 2008 at 4:23:24 PM | Revit 2009 : Area Separation and Mass Room Stacking and Blocking
afc4
3 Stars: 3 Votes
Room seperation lines seem to do a better job and will flex with the model. You can always get the same information using room seperation instead of area seperation.
Room Separation
Sat, Nov 3, 2007 at 3:19:41 PM
room bounding not recognizing room separation line [ 1 2 ]
Thu, Aug 18, 2016 at 10:02:14 AM
16
Room Separation Lines won't display [ 1 2 ]
Mon, Feb 19, 2018 at 2:00:11 PM
15
Room Separation Lines showing up from lower levels as halftone
Wed, Dec 22, 2010 at 12:17:20 PM
Room Separation Lines not plotting properly RAC 2009
Thu, Aug 6, 2009 at 5:47:46 PM
Page generation time: 5.5335
