Forums >> Revit Building >> Technical Support >> drawing a leader/arrowhead without text?
Mon, Nov 24, 2008 at 2:26:37 PM | drawing a leader/arrowhead without text?
savoy2
Does anyone know a way to draw a leader or arrow without text?  i'm using a family symbol for showing accent wall extents, and since I need the arrow to go around corners (which means it would need about 4 bending points), i'm trying to just use lines with a leader at the end of it.  but it won't let me draw a leader/arrow without any text attached to it.  any tips?  thanks!
Mon, Nov 24, 2008 at 2:32:33 PM | drawing a leader/arrowhead without text?
Use 1/256" text ... a "."
Tue, Nov 25, 2008 at 10:11:13 AM | drawing a leader/arrowhead without text?
JHectorne
There is also a "Blank Leader" family located in the "uncategorized" section of the downloads on this site.  I have used it myself and it works pretty well; you can specify the number of leaders; I'm not sure about the bending points, though.  HTH.
Jim
"You've got to remember that we are just simple operators.  We are people of the web.  The common clay of the new millenium.  You know...Newbies."
Mon, May 31, 2010 at 10:54:51 AM | drawing a leader/arrowhead without text?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just create a new annotation family of 'NOTHING'.
Then load and fine tune . . .  here's the CADclip > http://www.youtube.com/watch?v=k44pyzdM1b0
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:04 AM
Custom leader arrowhead
Tue, Jan 27, 2009 at 1:34:05 PM
Arrowhead start position with text box
Mon, Aug 3, 2009 at 9:19:59 PM
Room Tag Leader Arrowhead Problem
Thu, Jan 21, 2016 at 11:18:11 AM
almost have a work around for arrowhead styles - need input please!
Thu, Jun 4, 2009 at 7:31:36 AM
Page generation time: 0.2904
