Forums >> Revit Building >> Technical Support >> Room & Area Colour Scheme
Sun, Nov 23, 2008 at 11:27:12 PM | Room & Area Colour Scheme
riazadam
Hi there
I am trying to use the colour scheme to identif different departments. I have managed to place one scheme to identify the offices but i need to use a different on to indicate different workshops and i want to also be able to switch on and off the different scheme inorder to show the client the different area eg offices or only the workshop areas please can someone help me.
Riaz
Mon, Nov 24, 2008 at 9:14:28 PM | Room & Area Colour Scheme
mtyp
duplicate the plan with detailing and then have one set on the office colour scheme and the other set to workshop.
you can now flip between the two very easily
Mon, Nov 24, 2008 at 10:27:21 PM | Room & Area Colour Scheme
riazadam
BUT if i make changes to the floor layout will it change on both drawing or just on the one i am working on because then the way you are explaining will not work because one drawing will be "as built" and the other will not.
Mon, Nov 24, 2008 at 10:32:30 PM | Room & Area Colour Scheme
mtyp
If you're using walls and room separation lines this should be fine.  Those are model elements that are present everywhere, not just in one view.
Create a small test case first to see if you can get it to work how you'd like.
Mon, Nov 24, 2008 at 10:37:48 PM | Room & Area Colour Scheme
riazadam
cool i will try tks for the assistance
Area plan and colour scheme issue: 2008
Thu, Nov 29, 2007 at 10:39:39 PM
How to modify an area scheme - RAC 2012
Thu, Nov 29, 2012 at 2:51:01 PM
Elevation Colour Scheme
Wed, Aug 6, 2014 at 3:55:15 AM
Area Plan Color Scheme Cannot be changed???
Thu, Sep 11, 2014 at 11:58:37 AM
Room Areas and Colour Schemes
Tue, Oct 21, 2008 at 3:51:29 AM
Page generation time: 0.3809
