Forums >> Revit Building >> Technical Support >> Topographic points
Sun, Nov 23, 2008 at 10:40:20 PM | Topographic points
drclay
I am a beginner and was wondering why the points in the topographic follow each point for a while but when the topo cuts back, the line between the points skips points.  Is there a reason for this.  Is there a setting that I am missing?
Mon, Nov 24, 2008 at 3:28:29 AM | Topographic points
4 Stars: 205 Votes
Hi, I think i'm not understanding the real problem, can you put some images in Plan, 3d, to figure it out???
Thu, Nov 27, 2008 at 9:22:44 PM | Topographic points
drclay
I think these attachments are the correct ones.  one is from a section of Cal Poly Pomona and I tried importing it into Revit to create a 3D topo...that didn't work.  The second I used revit to creat something simular to the Cal Poly one but it elimated any complex curves.  It is sore of like drawing in Flash in the "simplify the line" mode.
I was looking to create the more complex variation on the Cal Poly topo.
Scheduling Topographic points
Mon, Sep 28, 2009 at 7:52:43 PM
Selecting Topographic Points based on Elevation
Tue, Aug 7, 2012 at 3:16:32 PM
Changed Levels to Correct Shared Elevation, now how to change topography points?
Tue, Nov 20, 2012 at 10:34:01 PM
TOPOGRAPHIC ELEVATION CHANGE
Wed, Sep 16, 2009 at 12:27:25 AM
Toposurface by points
Fri, Oct 8, 2010 at 5:50:31 PM
Page generation time: 0.4743
