Forums >> Revit Building >> Tips & Tricks >> Lighting in r2009
Sun, Nov 23, 2008 at 4:57:43 PM | Lighting in r2009
SteveB
3.5 Stars: 5 Votes
after much trial and error:  the problem in renderings is having the sunlight overpower the interior renderings with washed out hot spots at the windows.  Daylight portals didn'tt help.  Then i realized 2 things:
1.  somethimes 3d views get created in and EARLIER PHASE than the lights that get inserted.  you have to re-set the phase of the view or else the lights just don't appear.
2.  In some twisted effort to drive me nuts re-re-re-rendering a scene while and saving the planet one lighbulb at a time, all light fixtures come from Autodesk set to 12 watts.   re-set to 100w and they actually cast some light.  (clik on the light, "element properties / light properties", scroll down).  that re-sets them all.
3. recessed fixtures are fabricated to have the light source ABOVE the ceiling so they don't cast any light.  Edit the family, move the light source down.
Mon, Nov 24, 2008 at 5:01:47 AM | Lighting in r2009
4 Stars: 205 Votes
Steve, thanks for the tip, I know the last two points but I must admit I did not know the first point....
Mon, Nov 24, 2008 at 6:01:56 AM | Lighting in r2009
KingRevit
4 Stars: 12 Votes
good tips cheers
Tue, Nov 25, 2008 at 5:18:18 PM | Lighting in r2009
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Excelent tips SteveB...Thanx...
host sweep not working in R2009 when roof fascia option used on ridge and hip li
Sat, Sep 26, 2009 at 10:07:00 AM
Sky properties in r2009
Mon, Jan 12, 2009 at 11:23:25 PM
Why can't you upgrade your file to 2009? - I DID!
Mon, Aug 25, 2008 at 7:05:10 AM
interior lighting for exterior rendering [ 1 2 ]
Thu, Feb 11, 2016 at 2:03:04 PM
16
Electrical/Lighting plan [ 1 2 ]
Wed, May 13, 2009 at 11:27:51 PM
16
Page generation time: 0.0540
