Forums >> Revit Building >> Technical Support >> Topography and hatching in section / elevation
Wed, May 18, 2005 at 8:29:48 AM | Topography and hatching in section / elevation
phindes
Does anyone know how to turn OFF the default "earth" hatch that appears below the topo line when cut in section or elevation? I wish to show my ground lines "clean" below the surface, without any hatching, but I cannot find a way to turn off the default earth hatching. I do use a white filled region to mask this hatching, but that seems so clumsy if I could just turn it off. Any suggestions? Thanks!
Wed, May 18, 2005 at 10:39:52 AM | RE: Topography and hatching in section / elevation
TomDorner
4.5 Stars: 25 Votes
The hatching you see is controlled by the "cut pattern" of the material you assigned to your topo. Go to that material and simply choose a cut pattern of "no pattern" and you should get what you are after. HTH Tom
Wed, May 18, 2005 at 11:08:56 PM | RE: Topography and hatching in section / elevation
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is controlled in your Settings-->Site Settings-->Section Cut Material And poche depth, simply change here to get rid of the cut pattern.
Thu, May 19, 2005 at 1:12:47 AM | RE: Topography and hatching in section / elevation
phindes
thanks to both for your reply! Paul
Sat, Sep 27, 2008 at 7:55:41 PM | Topography and hatching in section / elevation
JI3ird
I love RevitCity. I have been looking all over how to get the earth to display. Thanks Mr. Spot!!!!
Topography Hatching
Tue, Feb 28, 2012 at 8:15:31 AM
topography elevation base
Tue, Mar 27, 2007 at 11:34:14 PM
how to turn on the hatching Pattern for topo in section
Mon, Sep 24, 2012 at 12:39:25 PM
Topography in elevation views
Tue, Jun 20, 2006 at 1:44:12 PM
Hatching
Wed, Nov 7, 2012 at 11:02:10 AM
Page generation time: 3.6133
