Forums >> Revit Building >> Technical Support >> can this made into a deck railing rac2008
Sat, Nov 22, 2008 at 10:36:16 AM | can this made into a deck railing rac2008
rquist
I'd like to make the enclosed attached file of a bench type deck rail as a deck rail system in Revit.
Just looking for a yes or no at this point.
If yes, is there a way to convert the bench framing member into a baluster or does it need to be made from scratch.
Haven't done much regarding creating content.
Tue, Nov 25, 2008 at 8:37:54 AM | can this made into a deck railing rac2008
tim123
4 Stars: 19 Votes
You can build a railing like this if you need to.
I am not sure how you modelled the supports - you may need to create new balusters from scratch although this should be fairly simple.
Deck Railing: Grrrrr!
Tue, Feb 20, 2007 at 8:28:29 AM
stair railing baluster properties not consistant with deck rail
Wed, Sep 3, 2008 at 11:08:32 AM
RAC2008- How to import railing from one file to another
Wed, Aug 1, 2007 at 11:23:34 AM
Aligning Deck Symbol Annotation to Deck Edge
Tue, Sep 4, 2007 at 12:21:20 PM
steel deck profile
Mon, Apr 24, 2006 at 4:59:54 PM
Page generation time: 0.4880
