Forums >> Revit Structure >> Technical Support >> Sketching in elevation view
Fri, Nov 21, 2008 at 9:41:25 PM | Sketching in elevation view
Justtegit1
I cant seem to do something that should seemingly be very simple: make a sketch in an elevation view.  I am trying to create a curved beam that is arched vertically (vertical curve).  I need to make the profile sketch in elevation obviously, but Revit wont allow it.  I know it is possible to make vertically curved beams in Revit Structure 2009 since I have seen images of it. What am I missing?
Sat, Nov 22, 2008 at 7:40:54 AM | Sketching in elevation view
4 Stars: 205 Votes
Hi, see the video and tell if this is what do you need: http://screencast.com/t/uufODohP
Sat, Nov 22, 2008 at 8:40:13 AM | Sketching in elevation view
Justtegit1
Wow thanks so much for making that video.   That was very generous of you to take the time to do that.  It was very helpful.  Like I thought, it was something simple that I was missing.  I didnt have any vertical reference planes drawn, so that is why no elevation choices were showing up when I had to "Pick a Plane".  Problem solved.  Thanks again!
Sketching Mode
Fri, Oct 26, 2007 at 1:58:22 PM
sketching & elevation question
Thu, Jul 21, 2005 at 1:53:00 PM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Making view titles reference each elevation
Mon, Oct 21, 2013 at 7:30:20 AM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW
Mon, Jul 29, 2013 at 4:50:17 PM
Page generation time: 2.8210
