Forums >> Revit Building >> Technical Support >> LEADER
Tue, May 17, 2005 at 10:58:32 PM | LEADER
yoiyoi
i would like to use a leader with arrows but without text attached . is that possible?
Wed, May 18, 2005 at 2:14:51 AM | RE: LEADER
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Create a blank text type then add a leader to the blank text... OR create an adjustable annotation for the leader and place as a symbol...
Wed, May 18, 2005 at 7:46:27 AM | RE: LEADER
yoiyoi
thanks Mr. Spot how do i create a blank text? and adjustable annotation? could you elaborate. a step by step approach would be helpful
Wed, May 18, 2005 at 10:50:00 PM | RE: LEADER
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I don't actual have the blank font type, if you do a search on augi you should find it somewhere though. For the adjustable annotation (which is the method we use) its a matter of starting a new generic annotation family with instance parameters to control the arrow length, head size, angle etc. If you created any families before its a fairly easy thing to do. Ours is actually a detail component which basically means it will scale with the view where as a symbol is always the same size regardless of view scale. I'll attach if need be.
Sun, Dec 30, 2007 at 8:37:09 AM | LEADER
boydj
Mr. Spot,
Not that great with families yet - I should be!  Although it was almost 4 years ago, I know you are on here a lot - would you mind attaching the blank leader you mentioned in the previous thread?  I downloaded one from here, but I unable to find a way to change the size of the arrow head.  It stays at 1/8" regardless.
I would greatly appreciate it - thanks!
Boyd
Multiple Leader Text
Sun, Nov 18, 2007 at 12:33:40 PM
Adding Snaps to Leader Lines
Thu, May 29, 2014 at 7:34:34 AM
Leader Question
Thu, Jun 16, 2016 at 12:24:28 PM
Positioning the leader on a tag.
Thu, Aug 6, 2015 at 12:16:39 PM
leader lines
Mon, Jan 19, 2009 at 2:39:06 PM
Page generation time: 2.5882
