Forums >> Revit Building >> Technical Support >> Curve Beam Quantification
Fri, Nov 21, 2008 at 1:57:06 PM | Curve Beam Quantification
MJMC22
Hi, I created a curved beam with the in-place family option categorized under structural framing, but I have a problem with the quantification. It only gives out the volume, but it doesn't give out the length as it does with the structural framing families created outside of the project. Is there any way I can get the length in the quantities? I tried by adding a parameter called length in the family, but no luck. Can anyone help?
Tue, Jun 30, 2009 at 9:46:17 AM | Curve Beam Quantification
sanne
My question is similar.. can I get the cut length of a beam in to the quantification?
Wed, Jul 1, 2009 at 6:20:25 AM | Curve Beam Quantification
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Hey I got the solution...check the attachment of revit project. After creating the curved beam with In-place family, you have to add parameters such as Angle, Radius. then Length with the shared parameter with 'Length' as Type of parameter. Then give the formulae 2*3.1415*Angle*Radius/360°. Now create schedule you will get length for the arc beam. 3.1415 is value for 'pi'.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Fri, Jul 3, 2009 at 12:51:26 AM | Curve Beam Quantification
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Hi I hope you got the solution...please let me know if you are still facing any problem.
Pavan Reddy
Revit Manager
Extension for structure
Sat, May 23, 2009 at 5:17:53 AM
Logo Placement in Curve Shapes
Wed, May 2, 2012 at 9:08:20 PM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Curve Walls
Mon, Dec 22, 2008 at 6:13:27 PM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Page generation time: 0.0792
