Forums >> Revit Building >> Technical Support >> Stair Tread Surface Pattern
Fri, Nov 21, 2008 at 1:25:54 PM | Stair Tread Surface Pattern
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
ok my surface patterns on my tread materials don't show in plan. Am I missing something here?
Fri, Nov 21, 2008 at 3:12:34 PM | Stair Tread Surface Pattern
4 Stars: 205 Votes
like what? like this?
Fri, Dec 11, 2009 at 9:37:51 AM | Stair Tread Surface Pattern
ashevilleARCH
I'm bringing an old thread back to life here.  I'm having this same problem and can't figure out what I'm missing...something simple I'm sure.  Can anyone tell me how to get the tread surface pattern (brick in my case) to show up in floor plan?
Thanks in advance.
Fri, Dec 11, 2009 at 1:13:27 PM | Stair Tread Surface Pattern
4 Stars: 205 Votes
Problem Solved?
Sat, Sep 4, 2010 at 9:00:38 PM | Stair Tread Surface Pattern
leothelionator
Override graphics in view might be one way to cheat the pattern into displaying, but you won't be able to use the actual model pattern, only a draft pattern.  Then the problem is that the hatch is no longer representive of an actual tile pattern since it cannot be adjusted, rotated, or sized appropriately.  There should be a way to get the model pattern to display in the plan just like with floor slabs and walls, etc.
Tue, Sep 7, 2010 at 7:51:11 AM | Stair Tread Surface Pattern
Homeytheclown
Homeytheclown Avatar
3.5 Stars: 3 Votes
I had similar issues, setting the grate pattern in materials is useful, but I couldn't get it to show up in a 3D View.  It wouldn't work on floors or landings, but would on stairs.  Kinda messed up.  But if I made a generic model with the grate material it would work.
Homey don't play that.
Tue, Feb 8, 2011 at 1:56:42 PM | Stair Tread Surface Pattern
allisonkapler
I've got a stair that I drew using boundry lines as well as risers, I assigned a material early on in the project and now I need to change the material. I selected the stair and changed the material of all the nessesary components, in plan it appears correct but in any 3d view i notice that the tread has not changed. If I draw a stair by run it assigns the correct materials but not if I draw a custom stair. All other stairs in the project appear correctly.  Suggestions?
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:20 AM
Stair Surface Pattern Not Displaying
Wed, Sep 8, 2010 at 10:05:09 AM
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
Stair Riser/Tread Number in Multistory Stairs
Tue, Sep 13, 2016 at 9:47:54 AM
Custom Stair Tread Profile vs. Default Tread Profile
Tue, Apr 30, 2019 at 2:28:08 PM
Page generation time: 0.2364
